OK so after all your lovely help from this topic
http://forums.overclockers.co.uk/showthread.php?p=23436108#post23436108
I've plumed for these bits.
Cooler Master CM-690 II Advanced USB3.0
Seasonic X-Series 650w '80 Plus Gold' Modular Power Supply
Asus X79 Sabertooth Intel X79 (Socket 2011) DDR3 Motherboard
Silver Arrow Extreme SB-E CPU Cooler (which is coming tomorrow)
And will be getting when the wallet permits!
Intel CPU Core i7 3930K
Pioneer DVR-220BK
Plextor 256GB M5 Pro Extreme SSD
Gigabyte 2GB GeForce GTX 680 3X OC Windforce 3X
Blu-ray Writer Quad Layer from Pioneer BDR-207EBK
WD 1TB Caviar Black Performance Hard Drive
I've finally made my first purchases and started the build off! All is going well so far with the Case and motherboard joined together!!! And I've started plugging everything in.
Here is where I'm up to so far.
As this is my first build I'm starting almost from scratch. I've installed most things in my current PC except for CPU/heatsink/fans in the past so sort of know where most things are, but as that was bought over 5 years ago, things have come on some, to say the least.
One question I do have if I may. From the top panel I've got everything plugged in fine except I'm not too sure about a couple of things. Do I need to have both the USB 3 and the USB 2 plugs plugged into the motherboard from the top panel? And I have a spare power plug from the top panel, does anybody know what it's for, it's one of the old 4 pin IDE male plugs?
I'm really getting into it now and can't wait until I can afford the CPU to finally get the thing powered up and running, HOPEFULLY!
Pioneer DVR-220BK
