Hello after deciding that my old setup was getting old I wanted to try and build the system myself.
My old specifications;
Athlon 3700+ 64
GeForce 6200 TurboCache
1gb DDR Memory
150 x 2 Seagate SATA HD
DVD/RW x32
My proposed new specifications;
Antec 900 Case (Not too sure if this is the best choice?)
EVGA 680i SLI Mobo'
Intel Core 2 Duo E6300
Zalman CNPS7700-CU 120mm Super Flower Cooler
2GB of Memory (Havent decided which yet, whatever is best for lowest price!)
Nvidia GeForce 8800 GTX
600W High Quality, Dual Fan ATX PSU With 2X SATA
150GB X 2 Seagate SATA HD (From old system)
DVD/RW x32 (from old system, wont really use it tho!)
If anyone has any ideas about how I could make this better / cheaper let me know, any kind of input is great, but most of all that it will work. Also would like to know what memory would be best, and also what case for the specifications!
Thanks a lot guys, hope to hear from you soon!
Matt
Athlon 3700+ 64
1gb DDR Memory
DVD/RW x32
EVGA 680i SLI Mobo'
Matt
