First mATX build issues with pic
Reset CMOS, un-tightened the CPU cooler and it did eventually boot but only with one RAM module in slot 2; slot 1 did not boot with either stick that was tested. I presume the motherboard is faulty?
Could still be a issue with some pins not making proper contact with the cpu thus only one of the memory channels is operating.
If this was the case, it would still be a faulty motherboard if pins were to fault?
But then they could just argue its been fitted incorrectly or something else.
Try the stock cooler and see if that helps (the pushpins will put less strain on the pcb
Thank you for the suggestion of using stock cooler. For a build I was doing today, this solved a problem similar to what the OP posted. :)
