Hi,
I built my new pc a month or so ago and seemed to be fine, however recently 3DMark05 started to crash (normally after the first test) however 3DMark06 worked fine... anyway I thought i'd give memtest a go, so I burned it onto disk and booted up with it and let it do its thing (not touched any settings as to be honist I havn't got a clue :$) anyway at time of writing (49 minutes) it has found 2 errors on tst 7. I dont suspect this is good... so is it time to think about sending the sticks back to OcUK? (Dual Channel 2GB corsair value kit @ £105 ish) Everything reguarding memory is default, no OCing etc.
Spec:
AMD 64 4000+
Asus A8N-SLi Deluxe
Leadtek 7800GT
Thanks in advance,
Brett
Spec:
AMD 64 4000+
Asus A8N-SLi Deluxe
Leadtek 7800GT
Thanks in advance,
Brett
