Exibit said:Keogh is the vcore ok ???
)Logic Zero said:Yes of course, you just change the settings back in your bios. And an E6600 stock is 2.4![]()
Marky said:Oops yes sorry 2.4
Would you recommend overclocking to 3Ghz? Once I have good cooling etc.
keogh said:Whats wrong with overclocking it now? You have an AC7? I have an AC7 and am at 3.5ghz, you could get 3ghz on the stock HS and fan!
And then I'll get overclocking
Do you have a guide I could follow to overclock the CPU?Marky said:Currently I'm recieving temps of around 45-50C at idle on both CPU cores. This is because I didn't apply any thermal paste, and only used the rubbish pad that was on the AC Freezer 7 Pro. I'm going to get myself some paste, and some paste washer-offer stuffAnd then I'll get overclocking
Thanks,
Marky
keogh said:I used the thermal paste that come with the AC7 Pro and my temps are fine... you sure its seated correctly? The stock paste on the bottom of the AC7 is Artic Cooling MX-1 paste (http://www.overclockers.co.uk/showproduct.php?prodid=TH-000-AR&groupid=701&catid=57&subcat=27) to my knowledge, not as good as AS5, but good enough.
You shouldn't have any probs really, I would deffo check the seating of the Cooler... make sure all 4 lugs are in their holes!
I'd follow the sticky guide on this forum for clocking it, its very easy to follow (http://forums.overclockers.co.uk/showthread.php?t=17612922). I dont have your board, so cant really tell you how to clock it Im afraid.
Marky said:I'm 99.9% it's fixed correctly in. When I built the system, I remember that I made sure it was a nice squeeze
Just brought some paste and cleaner, so I'll post the results by around Wednesday when I recieve it![]()
danielmayne said:hi am useing core temp but it tells me my voltage is only 1.3500v but in the bios i have set it to 1.4
