First Pc Build - Any Advice
30 Dec 2008
Hi all, just woundered if u take a look at what im thinking of building...Im one of these that like to have more than what i need although id like to say it couls beat ps3:P lol. This will be the first time i have built one and can u give me any tips of what to look out for ect.
3.3gh intell processor with 6mb cash (Dual core or quad core ?)
4gb 1333hmz ram
500gb 32mb buffer hardrive
750watt powersuply
Asus 1024mb GTX 280 graphics card
Blue ray Rw Drive
Motherboard to suite - Any idears ?
Windows vista ultimate( 32 bit or 64 bit ?)
Ive added it all up and it comes to 1500 with a case....So let me know what u think please.
spec (core 2 duo based, NOT SLi compatible, Crossfire compatible)
Your basket
Product Name Qty Price Line Total
Zotac GeForce GTX 260 "Maxcore" 896MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail £184.99
(£212.74) £184.99
(£212.74)
Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail £129.99
(£149.49) £129.99
(£149.49)
LG GGW-H20L Blu-Ray Rewriter & HD-DVD ROM Serial ATA Drive - OEM £115.99
(£133.39) £115.99
(£133.39)
Asus P5QC Combo Intel P45 (Socket 775) PCI-Express DDR2/DDR3 Motherboard £89.99
(£103.49) £89.99
(£103.49)
Corsair TX 750W ATX2.2 SLI Compliant PSU £74.99
(£86.24) £74.99
(£86.24)
OCZ 4GB (2x2GB) PC2-8500C5 1066MHz Dual Channel Platinum Series DDR2 (OCZ2P10664GK) £49.99
(£57.49) £49.99
(£57.49)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775) £17.99
(£20.69) £17.99
(£20.69)
Sub Total : £663.93
Shipping cost assumes delivery to UK Mainland with:
DHL @ Home Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.99
VAT is being charged at 15% VAT : £99.59
Total : £763.52
add case
suggestions
if you do a lot of encoding or use programs that can support more than 2 cores, go for a q9550 CPU or go for an i7 speced PC, if your budget allows
if you have plans for SLi ,you will need to change the MB to a nforce7 chipset based MB
if you have plans for crossfire, change to an ATI graphics card
if you are planning to overclock as far as the cpu can go or get a quad core, look at thermalright ultra extreme 120 CPU cooler.
I7 spec (note i have never spec'ed an i7 based PC before so a much better i7 spec should be put up by someone else)
Your basket
Asus P6T Deluxe Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard £214.99
(£247.24) £214.99
(£247.24)
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - OEM £199.99
(£229.99) £199.99
(£229.99)
(£212.74) £184.99
(£212.74)
(£133.39) £115.99
(£133.39)
(£86.24) £74.99
(£86.24)
G.Skill 3GB DDR3 NQ PC3-10666C9 1333MHz (3x1GB) Triple Channel DDR3 (F3-10666CL9T-3GBNQ) £71.99
(£82.79) £71.99
(£82.79)
Thermalright TRUE Black 120 CPU Cooler (Socket AM2/LGA775) £34.99
(£40.24) £34.99
(£40.24)
Sharkoon Silent Eagle 2000 120mm Fan - 3/4 Pin £6.99
(£8.04) £6.99
(£8.04)
Thermalright LGA1366 Bolt-Thru-Kit £6.99
(£8.04) £6.99
(£8.04)
Sub Total : £911.91
(This can be changed during checkout) Shipping : £9.99
VAT is being charged at 15% VAT : £136.79
Total : £1,048.70
why have you got 2 threads with the same title ( http://forums.overclockers.co.uk/showthread.php?t=17959341 )
