Greetings overclockers,
After a few weeks of research, I'm close to purchasing all the hardware for my first PC build, but I could use some help in finalizing my decision.
Budget:
£600-700
Purpose:
Preferences:
Reliable, long term, and fairly quiet; A little hum and small mechanical whirs are fine, not loud and obstructive.
Current search reults for build:
Motherboard- MSI B450 TOMAHAWK MAX ATX AM4 £105.21
Processor- AMD Ryzen 5 2600 3.4 GHz 6-Core £134.99
Video Card- MSI GeForce GTX 1660 SUPER 6 GB VENTUS XS OC £207.79
Memory- Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 £58.48
Internal Hard Drive- Western Digital Caviar Blue 1 TB 3.5" 7200RPM £34.38
Solid State Drive- Western Digital Blue 500 GB M.2-2280 £51.99
Mid Tower Case Corsair SPEC-05 ATX £44.99
Power Supply EVGA BR 500 W 80+ Bronze Certified ATX £57.40
CPU Cooler- CRYORIG H7 49 CFM £34.99
Total: £730.22
I still need to include a monitor, and an operating system. That would most likely add a minimum of £200.
Uncertainties:
1. Am I going overboard for my needs with any of the parts?
2. What is safe to buy used/what to avoid buying used?
3. Are the prices currently higher due to Covid? I can wait a little, if prices are going to dip/go on sale soon?
4. I care 0 about how the case looks, so long as I can fit everything in, and have good airflow. I have no qualms with tossing away a side panel. Drilling holes into it doesn't bother me either.
5. I'm not buying an optical drive, would that be a problem for the operating system?
6. Regarding the SSD, since the HDD will include 1TB of storage anyway, which would be more than plenty for me, is it ok to go for an SSD with lower storage space? I've seen Kingston 250ish gb, but some reviews say it causes random freezing. And does lower storage space on an SSD have any affect on performance vs a higher storage?
I'm open to well explained suggestions/advice/alternatives
For the sake of your sanity, be warned that I ask many questions.
For the sake of my sanity, please only reply if you have good knowledge on this subject.
Your time is much appreciated.
Budget:
£600-700
Purpose:
- Some 3D works,
- Some Illustrator/Photoshop editing,
- Video editing
- Gaming. Aiming for 1080p (1440p wouldn't hurt if the budget allows), Stable 60+fps As long as it looks and plays distinctively more smooth than a PS4, I'm happy. If you have any recommended builds for strict 1080p high settings, 60+Fps that coincide with my preferences below, I'd be happy to see them.
Preferences:
Total: £730.22
Uncertainties:
