first pc need specs checking
12 Jan 2021
Just seeing if anyone would be able to look through the specs of a pc I want to buy, budget of £800 (total is £800.27 rn) so let me know if you think anything needs changing or doesn't look right:
Case: Zalman S5 RGB Mid-Tower Case - White Tempered Glass
CPU: Intel Core i5-10400F 2.90GHz (Comet Lake) Socket LGA1200 Processor - Retail
Motherboard: Asrock B460 Phantom Gaming 4 (Socket LGA 1200) DDR4 ATX Motherboard
CPU Cooler: be quiet! Pure Rock Slim CPU Cooler - 92mm
Memory: Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
Graphics Card: GeForce® GTX 1650 StormX D6
M.2 Solid State Drive 1: WD Blue SN550 250GB NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS250G2B0C)
Mechanical Hard Drive 1: Seagate BarraCuda 1TB 7200RPM SATA 64MB Cache Hard Drive
Network Adapter: ADDON Wireless 11N 300Mbps PCI-e Adapter
Power Supply: Kolink Classic Power 600W 80 Plus Bronze Power Supply
Case Lighting: Phanteks RGB LED Strip Starter Kit (PH-LEDKT_CMBO)
Operating System: Microsoft Windows 10 Home Advanced - Systems
also to save an extra £40 I haven't selected a soundcard, because you can buy USB soundcards for like £8 if I end up needing it which should be fine?
appreciate any help
I wouldn't bother with the mechanical drive these days. There have been some great deals on good SSD drives recently.
That motherboard has built in LAN and sound.
so the pc will be just fine without a mechanical drive at all? I've taken it out and should I use the money taken off to get a better ssd or would you say the one already there is decent enough
