** First real home made rig **
oh dear, a bit of cable management needed here i think. even so well done for having a go. if you are going to put the side panel back on you rig then you should re-route those cables coming out of the PSU (the ones taped to the chasis with red insulation tape) makes sure you get them inside the chasis as you dont want to crush those cables.
cable onthe case frame is fine for themo, its got a lot of space. besideds ill clear it up more when i get the new wires or ill just be undoing what ive done, i made sure there not gonna get in the way of anything - had a mobo blow like that once - wont go into it (got a free replacement)
