First Semi Watercooling
26 Jan 2009
Hey guys i'm currently building my first ever gaming pc, and am thinking of getting an better CPU cooler, the current cooler i have is a stock intel cooler which i will to get rid of. So i would like to know who this CPU cooler fit into my computer case:
CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-015-CS
My PC Case
Thermaltake VH6000SWA Armor+ Aluminium Super Tower Case
If any of u can help me, with this particular situation and have any information on fitting this cooler within the above case, would be grateful.
Kind Regards
Hi deFiniLoGy
Thank you for the reply, that's great news that am able to fit this cooler into my case, erm when u say at the bottom your talking about the two optional hard drive caddies that can be removed right? Aslo are there any video showing you how to fit that cooler within my case or not?
Kind Regards
As above the H100/H110 will be okay at the bottom, the website I got specs on said nothing about the bottom 2 x 120/140mm spaces.
Right i see so i can use the h100 and the h110, with my case that is good to hear, erm can i ask whats different between the h100i cooling kit?
Thanks again for all the help you two have given me
Kind Regards
