first sff build advice needed
26 Jul 2013
Hello all, I've decided to make the move to PC gaming and would like some guidance on my first build.
As I'm coming from consoles I'm looking at a small form PC which will be attached to my 1080p TV- using Steam Big Picture. I'm looking for some advice from the OC community regards the components to use, specifically-
1) The case I'm looking at is the Cooler Master Elite 120. Given the dimensions and the fact that this is a first build, am I being overly ambitious here or should even a raw beginner not have too many issues fitting components into a smaller space?
2) What motherboard would people recommend for a case this size?
3) Processor and GPU. This is the element that prompted me to post in the first place. What would people recommend- given that this machine is going to be used purely for TV gaming? I've no previous experience with PC gaming and frankly felt a little 'spoiled' with the graphical performance of an Xbox 360.
What I want is performance that shows a marked, noticeable improvement over the 360- perhaps on the par to the 'next gen' consoles- but am a bit confused as to what Processor / GPU would get me what I'm looking for without 'overkill' (both system wise and £)
Anyway- apologies if this has been a bit of a ramble, but I look forward to any advice you guys are able to put my way!
