First SSD drive.
15 Nov 2008
Scotland / Blairgowrie
I have E130 to spend on a SSD drive. I dont know which ones to choose, all i want it for is to boot up windows 7 home premium.
Would 32gb be enough ?
also, is installing W7 exactly the same as installing it on a normal HDD?
For Win 7, I would think 32GB is a bit on the small side...although you might get away with the Intel X25-V Value 40GB or OCZ Vertex 30GB...
Something like the 64GB Crucial M225 would give you both a decent size and performance for just over your budget...
Basically yes, I would enable AHCI mode (rather than IDE mode) in BIOS first then install Win 7, once desktop appears you do the SSD Windows 7 Tweaks although I would leave the pagefile on C:\ (ie., on the SSD)...you could also update the ICHxR drivers (if this is the controller you are using) to 9.6.0.1014...
Intex x25
- Capacity: 40GB
- Read: Up to 170MB/sec
- Write: Up to 35MB/sec
- NAND Flash: 34nm Multi-Level Cell (MLC)
- Interface: SATA-II
- Low Power Consumption
- Lightweight (68g)
- Shock Resistant
OCZ Vertex
- Capacity: 30GB
- Cache: 64MB
- Read: Up to 230MB/sec
- Write: Up to 135MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Lightweight (77g)
- Shock Resistant
- RAID Support
- Warranty: 3 Years
to me the OCZ vertex seems the better choice, but will i notice a difference in them? its only booting up windows
