First SSD
27 Oct 2010
ireland
I am ordering my 1st SSD today. From my research the Samsung 840 is a good SSD for the price 120gb. Is there anything i should know before ordering my knowledge of pc's is limited i have a Thermaltake M5A case and a corsair cx500 power supply if that helps.
pro or basic? yes they are good drives
the size of the drive is important too as the larger the drive the quicker the speeds and lower the latency
there's £15 rebate on the 250gb atm but the 120gb is fine imo
you can use some elastic bands or Velcro to mount them if you don't wanna buy an adaptor,they are very light
you don't really need one,you can stand it up inside the case or stick it down if you wanted to save some money,it's upto you really
true,some cases let you mount them in the removable drive trays ect,so I would check your case
my fractal arc midi does so no tray needed for me:D
