First Time Build £1500 Bitfenix Prodigy
23 Feb 2013
UK
As the title suggests this will be my first build. Since the PS3 era is soon to come to an end with the release of the PS4, I have decided to hold off updating to the newer console and make the transition to PC gaming. I have a budget of about £1500 however I'd be happy to reduce this if possible although I'd prefer not to experience significant a drop in gaming performance. As a student living away from home my space is limited and I'd like to build a PC that can be transported with ease hence the need for building a mini ITX. I have a Macbook Pro for work so this will only really be used for gaming and perhaps a few file backups. Its been quite some time since I've sat and played games for any real length of time so i'd a PC that can handle anything that takes my fancy.
Unfortunately my knowledge of hardware and building is limited, I have posted below an image of the parts I intend to buy. Any feedback here would be much appreciated. I hope to put together a log of the build once all of the required parts have been purchased. I also have a spare 256gb Crucial M4 that could be used as a second drive. I have some time off my studies in a few weeks which would make an ideal time to put this build together.
I hope for this system to be as future proof as possible, i'd also like to place a lot of emphasis on cooling however preferably staying away from anything wet.
I will update the list shown above as changes are made.
I think the gtx 680 there is a 3 slot cooler while the prodigy only has 2 slots. also the cpu cooler might not fit as its a wide cooler so check that. also i think putting a 230mm fan while mean taking out the disc drive so maybe geta 200mm fan instead but check that.
also look at the samsung ram
and why do you want the low power CPU? why not got for a 3570k?
Thank you for the feedback, I guess i really need to look at this in greater detail. I'll take a look at all the points mentioned.
In accordance with the feedback received I have changed both the CPU and CPU Cooler, can someone recommend an alternative GPU? I have also decided to remove the disk drive to allow for the 230mm front fan and will use an external Blu ray drive if necessary.
Update: I have changed the GPU to the ASUS 670 4gb as I believe this is a dual slot. This has also helped reduce the total build cost by close to £100. I'd welcome any other changes that can be made to this set up.
Ask to make sure that GPU is 2 slot.
Also check the hight of the cooler as it might be to high to put fans at the top of the prodigy.
Are you set on using nvidea?
If you have an SSD put that as your main drive and the HDD as a 2nd drive. The SSD is Faster.
I've checked a few sources on the net that say it is a dual slot, I guess I should give them a call to make sure. Bitfenix claim that you can place a 25mm fan above this cooler although from what i've seen it will be tight. I've no real preference between AMD and Nvidea GPU's although this mainly comes from my lack of knowledge, I guess I am just looking for the best performance at £400 or less.
I will use the M4 as my main drive, thank you for you help.
In terms of gaming performance is there much difference between the i5 3570k ivybrige and the i7 3770k ivybridge? This could potentially help shave another £100 off the total cost of this build although this does depend on how significantly performance changes.
For gaming there is no difference between the two save that £100. Maybe a few % but deffo less then 5% decrease in performance but this is due to the slightly higher clock of the 3770k.
Have you looked at all in one water cooling for a heatsink?
Also what resolution you playing at?
A possible 20% reduction in performance sounds a lot. I'll keep my eyes open for various alternatives to the ASUS 970 4gb though.
I found the Spectre Pro's to be quite noisy, I had one
in the front of my 650D but replaced it with a coolermaster
megaflow. Much quieter.
At one screen at 1080p the card a basic 7950 or 670 will max out the settings on all games except maybe witcher2. A 7950 is cheaper though. You won't need a 4gb card you won't use it.
Also if your that botherd about the noise, look at the foam kit for the prodigy for £20 on overclockers should help with some of the noise when its not doing much. Also for the sound card you would have to look at a external one. the slot used for it is used by the GPU and theres only the one slot.
I think this build list is now pretty much complete, turns out to be a £1200 build which I'm happy with. Could have perhaps spend the other £300 on a improved graphics card but for now I'm hoping this will do. I've also made changes to the fans in order to allow the use of a Blu Ray drive.
How much does the foam kit affect the cooling performance?
I'd also like to use Bitfenix's alchemy cables, could someone please list the cables that I will require for this build.
