First time build, need advice?
13 Aug 2012
This is my spec, this my first time build and I was curious as to what I should do once I have windows 8 pro 64bit installed etc:
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail
2 x MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** with FREE GAMES
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW)
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (PV38G213C1K)
1 x Thermalright True Spirit 140 BW Cooler
1 x XFX ProSeries (XXX Edition) 850W
1 x Fractal Design ARC Miditower R2 Side Window
1 x 27" 2560 x 1440p IPS screen
The cooler is a bit errr not quite good enough for such a great board which is capable of making your CPU reach its full potential if you want too.
Ok, but check it fits in the case, you should be able to find the cooler clearence on Fractals homepage and the cooler height at Thermalright.
