- 6 Nov 2011
Hello, I built my PC late last night, so didn't get chance to really test it last night, anyway when I come to test it this afternoon in my 19 inch tv via HDMI it just wouldn't boot and there was no video output at all. I fixed this problem by unplugging the PCI-E lead from the gpu and for some reason it did boot and show video out put. However I turned it off and went to install Windows 7 and then I couldn't turn it on when I flicked the PSU switch there was just a green light flashing on the Motherboard and it won't even turn on at all.
Things I've tried after a little bit of research:
.Removing the PSU and all cables and putting it back in and hooking everything back up.
.Removing the Ram and re installing it.
.One ram stick to see if it would boot up rather than 2.
And none of these have worked at all . Any help Would be highly appreciated as I'm frankly terrified something has happened, I've attached some images below of the Motherboard and cables.
The build:
Motherboard:Asus H81L-Plus
CPU: I3 4330 3.5GHZ
GPU: Msi radeon r9 270 twin frozr edition
Case: Corsair Obsidian 250 d
Ram: Hyper x 8gb
PSU: Corsair cx 430 w
Cheers,Jack
The build:
CPU: I3 4330 3.5GHZ
Ram: Hyper x 8gb
Cheers,Jack
, hit the power button and nothing turns on at all. But before when it would turn on if you disconnected the PCI-E ye it would show a display. If you kept it in a display wouldn't appear.
