first time build. Will it work?
what is your budget? The spec you have come up with will work, but did you know you have chosen a micro atx motherboard board when that case can support up to atx size mother boards. Also unless you have one already it would be best to get a aftermarket cooler so that you can overclock that i5 3570k. may this moterboard and cooler
http://www.overclockers.co.uk/showproduct.php?prodid=MB-391-GI&groupid=701&catid=5&subcat=2261
http://www.overclockers.co.uk/showproduct.php?prodid=HS-102-TR&groupid=701&catid=2330
another thing to consider is waiting a few weeks because some new intel cpu's are going to be out which will have slightly better performance.
