Ok so I've never built a gaming rig before. I'm a complete noob but I have been given some advice by a friend and his top tip was to come here and ask the wonderful people on the overclockers forums for some feedback on my basket . I'm going for a high-end rig solely for gaming.
Currently in my basket I have:
Before I even set about picking parts I had already decided that about £1300 would be my budget, so I'm not far off. But obviously I would love to save money wherever I can.
Some specific questions I have:
Any further comments or suggestions are more than welcome. I need all the information I can get before I part with this rather large sum of cash.
Thank you in advance!
- GPU: 1 x MSI GeForce GTX 1080 GAMING X 8GB GDDRX DVI HDMI 3 x DisplayPort PCI-E Graphics Card = £594.96
- CPU: 1 x Intel Core I5-7600K 3.80GHZ Socket 1151 6 MB Cache Retail Boxed Processor = £225.34
- Motherboard: 1 x Asrock B250 Pro4 Intel Socket 1151 ATX Motherboard = £95.48
- RAM: 1 x Corsair Vengeance LPX Red 8GB (1x8GB) DDR4 2400mhz 1.2v Standard Dimm = £62.99
- SSD: 1 x SK hynix SL308 250GB 2.5 SSD = £73.94
- PSU: 1 x Ace Black 120mm Fan 600W Fully Wired Efficient Power Supply = £16.86
- Case: 1 x NZXT Source 340 Mid Tower Case - White = £62.97
- Monitor: 1 x Asus VX24AH 24" IPS Console Gaming Monitor = £209.00
1. I gather that the RAM and CPU don't matter that much for gaming so I perhaps I can save money there by getting some cheaper parts. Are the CPU or RAM overkill? If so, what would you recommend?
2. With the RAM, is it fine to get just 1x8GB? Or should I buy in pairs so 2x4GB for example? Somewhere in the back of my mind I feel like I've been told that RAM works best in pairs but I might be imagining it.
3. I am totally clueless when it comes to motherboards. I have pretty much just arbitrarily picked a reasonably priced one that's compatible with the CPU. What should I be looking out for here? My friend mentioned something about whether or not the motherboard comes with good audio capabilities but honestly I am just overwhelmed by all the acronyms and technical jargon at this point! xD If anyone can recommend a more suitable/cheaper motherboard that would be great!
4. I've also got no idea about cooling but after reading around a bit it sounds as if the cooling that comes with the case (2 fans) and the cooling in the GPU should suffice as long as I don't overclock like a crazy man. Is that right?
5. I've left the SSD there on its own with a HDD because I just don't think I'll need more than 250GB for quite some time. If I ever do need more space I can always add a HDD or another SSD in the future right. Does that sound reasonable?
I don't need a keyboard and mouse as I already have them.2. With the RAM, is it fine to get just 1x8GB? Or should I buy in pairs so 2x4GB for example? Somewhere in the back of my mind I feel like I've been told that RAM works best in pairs but I might be imagining it.
