http://www.overclockers.co.uk/showproduct.php?prodid=GX-119-MS&groupid=701&catid=56&subcat=1752
If you don't mind ATI this 6950 is a revision 1 card which can be flashed to make it a 6970 (got one myself and it is awesome) plus it is about £25 less than the 570
http://www.overclockers.co.uk/showproduct.php?prodid=BU-004-CM&groupid=701&catid=7&subcat=29
Also this case and power supply is a good deal if your not bothered about crossfire or SLI (The other power supply you have is a bit overkill if you are not bothered about two graphics cards) I will also save you another £70
Could use the money saved to get a nice 60gb SSD drive
