Yes, true, the white edition has definitely been out for a while.Looks like it was released a while back so not really sure on the OC Black.
No worries - best of luck with the buildBut yeah again thanks for all your help![]()
No problem.I will look to OC the CPU yeah. The water cooler is a bit of self-indulgence over anything else if i'm being totally honest.
I've built with the below in the past - it's designed for silence in mind - and has a classy minimalist look in the flesh:*edit* The 400C seems to not be the best for noise looking at it, aesthetically though i really like it. I've actually really been struggling to find a case i like and this is one of the few that i do like. The Enthoo Evolve i did like the look of as well, i might check the sound levels for that.
Very envious - having to delay my build until the builders have finally vacated - so much dust i dare not bring a new system into the house.Will post pics once this is all done though, hopefully it won't be a sad me with a smoldering ruin![]()
So got everything today, wohooo and it seems like it actually works. Only problem is the Aorus card has a dodgy fan that rubs![]()
A little bit of me regrets the water cooler as well, I dunno if it's just me but the pipes are quite rigid and trying to mount it on the front ended up the case wouldn't shut right because the way the pipes bent
I now understand why people do a test outside the case now, I was just too nervous to do that.
But yeah it turns onwill flash the bios tomorrow then look to install windows.
Yeah I ended up having to take a ram stick out to get it to boot, think once the bios is updated it should fix the issue.
Thanks for the link too.
Also only realised today how horrid the sag is on that 970. Think it might need a little lego support.
