- 2 Feb 2007
- Belfast
Hey guys,
Finally decided to go watercooling for my latest build. I originally ordered a Corsair H100 but had a million and 1 problems with it and sent it back for a refund.
I've done quite a bit of research already and have came up with the following parts:
YOUR BASKET
1 x EK Supreme HF CPU Waterblock - Nickel Acetal £55.99
1 x XSPC EX240 120mm Radiator - Black £39.98
1 x EK DCP 4.0 Pump (12v) £39.98
1 x EK Reservoir Combo DCP 4.0 £24.98
3 x Phobya Nano-G 12 PWM 1500rpm RED LED Case Fan £10.99 (£32.97)
1 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m £10.88
2 x Mayhems X1 UV Red Premixed Watercooling Fluid 1L £7.99 (£15.98)
6 x EK PSC Compression Fitting 7/16 [16/12mm] - G1/4 - Black £3.50 (£21.00)
Total : £253.81 (includes shipping : £10.00).
I know that I may be skimping out slightly on the pump for example but will I really notice that much of a difference? I'm really at the peak of my budget already.
Also, I won't be buying the coolant from OCuK as they only have clear or UV (which I hate), unless of course they suddenly decide to get some in (wink wink).
Opinions would be great and also let me know if I need anything else
YOUR BASKET
you failed to deliver cleeecooo
