First-timer question about CPU temp & voltages
I started building PCs 20 years ago, and built hundreds in the 90s, but, although rusty, I was frustrated with mediocre performance. So this is the first time I've tried an overclock.
I used the excellent guide in this forum's sticky post. I managed to get a Core 2 Duo E7300 2.66GHz & Corsair Dominator Twin DDR2 PC8500 up to 3.33GHz (FSB333) on an Asus P5Q Deluxe (P45/ICH10R) without much trouble. Sandra says I'm getting about 25% benchmark increase, across the board, and I even overclocked my ATI 5670 by 15%. So I'm a happy bunny. I'm sure I can go further, but I've stopped here for a rest for a few days to make sure it's all happy, and listen to the fans speed up when I do tricky stuff in Photoshop.
Anyway, Coretemp and Realtemp wouldn't work on my system. They both said my CPU was fixed at 58 degrees. So I ended up downloading Asus's own 'PC Probe II', which is dated July 2009, and appears to annoy Win7/64 enough to autoload some extra 32 bit stuff at boot-up. I can't say that I've been impressed with Asus's software. Does anyone know if there's a workaround for this system for Coretemp/Realtemp etc?
Also (and you'll cringe at this), apart from a RAM voltage set to 2.1V, I have my board voltages set to AUTO. This is mainly because I haven't got a clue what to set them to manually. CPU-Z says my Vcore is 1.224V, which I believe is fine, but I have no idea what the other voltages are doing. As a result, I'm hestitant to push any further. Any pointers, please?
