Ok, so I'm taking the plunge and am going to watercool my system. You can see my rig at the moment in my signature. It might help to know I have an Antec P182, which has the two holes at the back for watercooling pipes (or at least that's what I've always figured they're for!). OK, I'll sort of list my queries etc. Bear in mind I have read the beginners articles for watercooling. I'm just going to be extra thorough as I'm quite nervouse about making this move.
1. I want to watercool the entire system, GPU, CPU and northbridge. What parts will I need to do this? I'm guessing, waterblock for the CPU and GPU, radiator, resevoir & pump and tubing. What will I need to cool the northbridge? Another waterblock?
2. What pump would you recommend to cool all of this?
3. What is the best waterblock for a cpu currently on the market
4. Is it the radiator which recools the liquid?
Money is no object for this. Basically, a thorough detailed response would be awesome, many thanks in advance for taking the time to help
