- 6 Aug 2010
Dont worry, i have spoke to someone else, all my parts have been ordered will post a picture from my phone once it is complete. Thanks for your help.
Hey my build is complete! How do i link put pictures on the page? is their like an upload thing, it keeps wanting me to link them, but they are not online anywhere.
you need to use the direct link. here it is:
http://i38.tinypic.com/4gits3.jpg
it's looking good, especially for your first time! VERY VERY tidy as well! I hope my first wcool is as neat as this!
well done mate
, im really happy with the results, the loudest thing in the system is the pump, it makes this really annoying humming sound! Its an xspc 750 dual bay resavoir, i think it may be broken. Im so tempted to do the gpu's awell, mod the bottom and put in a 240mm rad lol.Hi,
I am looking to watercool my i7 920 CPU and 2 x 5970 video cards. I know absolutely nothing about watercooling but i am trying to get my head around it all
I know i will need a new case, the 800D seems very spacious so i might go for that one
This is the list i have put together so far, please tell me if anything is incorrect or anything you think i should change. Thanks for your patience!
I know this is proberbly not what you want to hear but this needs to be said
If your first time water cooling then COOL your CPU only. When you get used to things then expand your loop
what temps are u getting with ur setup full load?
To be honest there is no easy way to cool an i7 and 2 high end GPU's without modifying a case. The only other case I can suggest is the Lian LI-PC-P80B or Silverstone TJ07 which stiull require modding to fit the required rads.
