First WC Advice
26 Feb 2012
Hi all,
I know this has been here like million times but I`d rather ask then mess something up. I have been doing a lot of reading about WC and have decided to give it finally a try but got a couple questions.
I run - asus hero 8 mobo, 6700k skylake at 4.6ghz, corsair ram, fury x all in corsair 750d case.
I decided that I for stat just want a WC CPU, however in the near future I would probably add the gpu as well. I know I do not want a bay reservoir I would prefer to have a stand alone one in the case. I do like the aesthetics of it so I was thinking to have that somewhere on the hdd cage or so and then run the loop to top radiator.
Can you recommend a set up that I could for now only run a cpu and then later in the future if I decide to add GPU I will be able to use the same just add rad perhaps?
Another thing is what sort of improvement on the cpu temps am I looking at compared to corsair h100i gtx?
Also what are ALL the exact parts I would need for this?
Many thanks,
Tom
Overclockers v12 watercooling kit, everything you need. look at everything there Change the res if you want a tube style or take note of whats included and order seperatly.
Check the 750d thread in the case section for various watercooled builds.
