First WC Build - Advice Please
3 Feb 2009
So as the title says i'm finally getting on to my first WC build using the setup that I already have.
I have ummed and ahhed about cases for a while but I think i'm going to settle with an 800D from Corsair but if anyone can make a better suggestion I would be happy to consider it.
I will be cooling an i7 920 and a 570 GTX (both OC'd reasonably heavily) and would like to leave some room in the temps for a 2nd GPU and future upgrading.
After reading as much as I could around the subject I think i've come up with a basket which will get me everything I need in one fell swoop but first I have a few questions so any help would be appreciated.
Here's what I'm planning to buy first off:
VGA Block - Can't find anything better (and I assume the MSI version I have is the stock layout?)
360 Rad
CPU Block
Res/Pump Combo
Fittings
So, on to the questions:
Will 360 be enough raddage for what I need? I have seen some people recommend more for a loop with a 2nd GPU but from what I read it's enough for an OC'd CPU/single GPU? Is it worth adding another 120 in somewhere just for some extra coverage?
Pump/Res combo's - are they worth the money or would the difference between the one i've picked and getting a discrete res and pump be really noticeable? Ultimately i'm going for as quiet as possible here above anything else.
Fittings - Am I correct in assuming that the GPU block I linked needs 2 caps to close off the unused side when there's one GPU in the loop? Also, with that pump/res combo i've picked do I need to replace the fittings pictured with what i'm using or will slipping the tube over the barb and using a cable tie do the job well enough?
(to make sure I can count 8 fittings and 2 caps total?)
Thanks in advance to anyone who makes it through this and responds!
I would buy a better graphics cards before going to watercooling personally, 570 SLI won't gain you anything much in newer games as they will be VRAM limited in quite a few titles... sell the 570 and get a 670 - possibly a windforce, and then maybe have a look at a CPU only loop to get you started
Also, if you intend to watercool your GPU always buy the reference model of the card or you could end up without any companies actually making blocks for the card.
Well a WC loop wasn't really an option back when I bought the 570 but now it's become an option i'm looking to see what I can do with it. I'm still not sure about 3.120 being enough rad for GPU and CPU though
Will be fine for a 670GTX and a CPU, if you go for a thick one it will be overkill (which is good). Due to design improvements the GTX670 has roughly the same heat output as the 560Ti did.
