Hey guys, hope you can help.
I've just set up my first WC build (based around the OcUK V8 kit) and everything is running smoothly, except one worry I have with the EK DCP 4.0 Combo res. When I first started filling the loop I could see the threads on the res start letting water around them and every time I stop and start the pump with the res top on it moves further and further down, like so:
Nothing has come out yet but ive got it on a bed of toilet roll just in case. It is as tight as I can screw it on, it only moved a couple of mm from being fresh out of the box so I don't think it needed tightening really!
Also, should the mayhems pastel be very frothy? I rinsed out everything with mayhems pure H2O prior to the build.
Last but not least, a work in progress shot:
Cheers
Craig
Cheers
Craig
