- 23 Apr 2007
- Cardiff-ish, Wales
Hi guys,
I've just received my order from OC including an i7 2700k CPU, an Asrock Extreme 4 Gen 3 Mobo and the OCUK v12 watercooling kit.
First things first, should I install the PC with the retail fan to make sure it all works first? If so, should I go as far as installing the OS, or just make sure it boots into the BIOS?
Cheers,
Jed.
Cheers,
Jed.
. You might want to consider the use of pump foam to reduce vibration resonance if the pump vibrates to much against a surface (give it a test in different locations really). Though you could probably minimize this by changing the pump setting to 1 or 2 without sacrificing thermal performance as you have a small loop.
