First WC loop.....
Thanks Hakanese, I kinda like the looks of the sp120s over the GT's but i guess i could spray up the GTs without affecting the performance right? - Adam
Thanks for the feedback Daveip.
Come up with a slightly different setup after double checking the scales of everything, here it is...
Another quick question everyone, does anyone know if it would be ok to use both rigid and flexi tube in a loop? The rigid pipe will be 10/12mm am I right that if I wanted to swap onto compression fittings I would be wanting to get 3/8 1/2 flexi tube/fittings as that's the closest size to my rigid tube? Thanks - Adam
