It looks a lot thicker in the picture than it actually is!That's a lot of TIM on the CPU!!!
Also did you buy the GPU blocks recently?
ThanksLoving it so far! Anything you're still waiting for?
Nope, have everything now, well, will do tomorrow when my red braided cable kit from Corsair turns up
Thanks:Looks great! Far neater than my feeble attempts![]()
I'm trying to keep it as tidy as some of the more professional looking builds I've seen on here!Yeah, it seems to have gone like that about an hour after I fitted it.Looking good, might want to keep an eye on the tube between the CPU and motherboard block, it looks like it's trying to kink.
Got the GPU blocks about 4 weeks apart. Build was originally going to be a single GPU but had to wait for some kit so ended up buying another! Got one directly from EKWB and the other from another vendor as OCUK don't sell them![]()
Was going to say the same about the possible kink on the tubing between the mobo and CPU block... You could fit a couple of 90 degree fittings and some of those acrylic tubes if you wanted to be super cautious and neat... Still looks amazing though mate![]()
Think I'll just use the 45° fittings I already have, this build has already cost me a small fortuneAgree with above 2x 90° connections between the CPU block and the board cooling with a short section of pipe between. Acrylic is OK if the connections are in line and not slightly off set a short section of pipe would allow for any differences in height.
What was the reason for putting the gpus so far down?
