First WC Project
When your system is running, just lean the whole thing over to the left and right as much as possible and then forward and back. I did this after draining the loop and its surprising how much air came out.
Hi TheKnat
Could you list the components that make up your watercooling setup, blocks pump rad barb sizes tubing greenstuff type lol :) I am tracking the watercooling setups and its good to know what goes into them as I'm not savvy enough to recognise the components by eye yet.
TIA
What do you mean ? They're for different things :D
On another note, I'm debating what to do about this system. I'm leaning towards taking the GPU out of the loop as I'm not going to clock the cards at all and they don't seem to be running hot.
Does anyone know of a good replacement heatsink for the 8800 ? Just because I think the wife has binned the old one.
That was a ninja edit if ever I saw one.
Replacement aircoolers for the 8800 series are pretty thin on the ground as the stock ones are good enough and also run pretty quiet.
I love my EK block though - best looking waterblock ever imo.
Hmm so I'm left with a choice. Either leave the current one in the loop and have my CPU not as cool as it should be or take the card out completely until I'm ready to install a better/second loop to handle both GPUs.
Does that waterblock also cover the ram as well ? Had major difficulty with the little stick on ram heatsinks.
TheKnat said:
List of components:
Kit
Liquid
That didnt take long :D
sneaky edit
Thanks for the setup detail :)
Tasty block all right.
P.s.
Whos been helping with the childrens spelling ? ;)
Your inlet to the cpu block is at the top. There is a small (very small) chance there is air trapped in the cpu block.
1 Loosen res so that you can orientate it to keep it upright.
2 Lay case completely on it's left side (open side), makin sure res stays upright. Let it run for 5 mins like this, shaking occaisionally. This should get the air out of rad if any left.
3 Lay case completely on its right side (mobo side), again make sure res stays upright. Let it run and shake. This should get air out of cpu block.
At least then you know for sure it will be bled properly before you take any further action.
:D
I'm in the middle of tidying all my cables at the moment. Temps are slowly dropping off but I think its getting near its limit
:D
Well spotted !
There is also the pin orientation to check to sure the main flow channels are parallel between the inlet and outlet:
I did wonder what that bit of paper was going on about, now i know!
I think I may need to remove a few of the components and then re-fit them better. Anyone got any advice on how to get the water out of the system ?
Release a block or pump / res to outside of the case, remove a hose connection and let it drain under mavity, lifting & rotating the case as required.
Do not power the pump to move the water when draining as it can be easily damaged without being full of water.
