I'm over to a friends later to re-fit his Tuniq Tower which is running pretty hot.
We did the credit card method to apply the thermal paste, but I think we'll do the horzontal line method this time because his temps aren't great. I guess his IHS isn't perfectly flat so isn't making perfect contact, and needs more grease to fill in the gaps...
Can someone try and describe how tight we should tighten the screws, too? I've never screwed a cooler onto a mobo and neither has he, so it might be too loose.
Also, we didn't take the cover off the backplate's sticker because he didn't really want it stuck to his mobo. There's no problems with that are there..?
Any advice on getting his CPU as cool as possible with this cooler are appreciated
He has great air circulation (Antec 900 with the side off) so no problem there. Cheers
but ma gawd its bolted on well.......(obviously dont do it this tight unless you know exactly what your doing ! /disclamier!) I get 41c load on my opty at 2.75 after 24 hours dual prime
, my mobos dead and i wanna move the tuniq over to my new board, any suggestions as to removing the back plate from the mobo (without destroyin the mobo)
