Fitting alcove units - what ventilation do I need?
20 Oct 2002
London
We just had a carpenter round to quote on building some alcove units very similar to this;
Inside will be;
- Marantz SR5012 (w/ 2 usb fans on top blowing backwards)
- SkyQ box
- AppleTV 4k
- Harmony hub
- Sky router
- Hive hub
- Some cheap unmanaged switch (yet to be purchased)
I'm currently deciding if my Panny GT60 will stay and get wall mounted, or it's time to upgrade :(
Question is, what do I need to do regarding heat? I'm thinking definitely some vents/slots at the top back as a minimum but would you insist on having some airflow coming in from the front? Perhaps a lattice or cane panel on the door, but then you'd see all the LEDs?
Stick it all in and forget about it! Will there be some holes in the top of the cupboard for wires? I presume the amp will have the required air gaps around it inside the cupboard? The cupboard doors won’t be airtight so some airflow will happen and if there’s an exit in the top I dare say you’ll be absolutely fine.
A few years ago one of my customers was facing a bit of a dilemma about equipment storage in the lounge. With two young kids running around he wanted everything to be secured away out of reach of prying fingers. There was also the WAF requirement for it to be as small a unit as possible. Knowing what I nightmare finding the right cabinet can be, I pointed him towards the web with some starting suggestions and left him to it whilst I got on with prepping the rest of the system ready for the couple of days installation.
It was no surprise that he came back frustrated. Most ordinary furniture pieces weren't deep enough for the AV amp. The odd pieces that were were either too big over all, or lacked the doors, or they just looked wrong for the room. Anything fully enclosed lacked ventilation, and the prospect of butchering some newly-purchased cabinet didn't appeal to him. At that point I agreed to look at designing something to fit the brief.
This is what I came up with for him.
It's not possible to see from the outline sketch or photos, but the left side panel of the cabinet had a couple of large holes then covered in speaker grille fabric. It was essentially open to the side where the amp and Blu-ray player were. The rear panel was held on with magnets. That meant it can be removed for ventilation as well as easier cable access. The shelves beneath and above the AV receiver (Onkyo 8xx series) were slotted as shown to aid convection cooling. The amp still managed to have a HDMI board failure due to heat, but no quicker than any that were on racks open to the front and rear.
The more open ventilation slots you can have in your cabinets the better. Ideally you want forced air pulling the heat up and out. Grilles on the cabinet doors will help, and to get around the issue of seeing the display LEDs, you can have a double layer built into the door so that a blanking panel behind the grille allows air flow whilst stopping light from the rear. Alternatively, have the base plinth height increased and create ventilation slots all along the edge, again covered in white grille fabric, so that cooler air is pulled in low. The point here is that if you're having this built bespoke, then you have the opportunity to design in the ventilation to suit your needs.
Here's some more food for thought: https://acinfinity.com/pages/hvac-setup/cabinet-cooling-and-ventilation.html
Will overheat if no proper holes to let a convection current happen
Indeed. My current Besta unit is totally open at the back, and I have two of these AC Infinity fans blowing backwards and the unit still feels very warm inside.
Thanks for the info, ideas and links. Where did you get the speaker grille fabric? We're toying with the idea of a grill like one of the first few listed here but the problem is where exactly to put it. If you look closely at the pic above.. we'll definitely want skirting so there's no real gap anywhere to put holes in the front :confused: The back I'm not so worried about - we'll just have a big slit/slot along the back (like in your pic) and hope it's not too visibly. Probably won't be with the telly in front of it anyway. I'll also get him to put a million slot holes in the shelves I guess!
At the time I think it might have been Wilmslow Audio. I've just had a look though. Their web site has been redesigned and there's far less ranged in the way of parts for the custom builder. You can search eBay though and find plenty of options in various colour, including white and cream. Try this item number as a starting point: 295282534776
Is that picture in the first post close to what you're aiming for, or do you have a slightly different design in mind with mentioning the skirting?
Regarding the top rear slot, I can think of some ways to disguise the vent function by incorporating some up-lighting. Whatever you do though, don't hand off the designing of this to a joiner unless they have specific experience in ventilation and designing for AV. To be blunt, the average joiner doesn't have AV gear at home, and so they don't really understand what's required for things such as cable access and ventilation space. Because they have little or no experience about it, they can't design for it. What that means is you'll get pretty boxes, but they're an absolute ba****d to work with.
I've had this on a couple of jobs where joiners have designed media units. Trying to hold 20kg of AV amp hanging off the two back feet on a shelf whilst making all the connections in a dark hole with limited visibility because there's no room to swing the amp around, and oh yeah, be careful of the veneer or paint finish on the shelf edge. Then when it's connected you find that there's now no space for the cables that had to be left extra long to reach as the amp was pulled forward. Just bad planning.
Design it yourself, or put the designing of it into the hands of someone who understands the requirements.
@lucid - absolutely agree with designing it yourself. One issue with the depth of the unit will be how deep the existing alcove is. In practice these things are usually fine if there's a chimney breast, but AV amps with banana plugs hanging out the back quickly take up space.
Thanks. An out-there suggestion could be a square grill in the middle of each door as a feature. But I'm not sure how much airflow will actually come through? (And it might look absolutely tragic :p )
It was a quick Google but actually super-close. We want floating shelves above like the pic (not built in above). And byes skirting is going to be a big decision. We have taller skirting around the room and it's plain. So what is in the pic would look great... but the question remains where to potentially fit grills. My other half was suggesting putting them in the skirting/plinth a bit like what you get underneath a built-in fridge. But again, we'd have to be brave and make them a feature. For reference, the room will be dark green/blue/teal, it has brass plug sockets, a black traditional radiator and white-ish fireplace surround (around a cast iron fascia). So it's going to be a dark-ish room with white woodwork and brass elements. So a brass grille could look great in the skirting. Or could look naff :(
I get that and essentially I will be designing it, I suppose. He was asking about cables etc. so he does have some idea. I read somewhere else that pull out shelves (on runners) is very useful. Maybe just for the amp? :confused: At the end of the day though, this isn't a particularly high-end setup. It's just the amp I want to take proper care of :)
Depth should be fine. My amp and cables fit fine in the Besta and the depth can be slightly deeper than that. Granted I won't be able to get around the back of it though which makes things more difficult.
How about a false bottom where the skirting is and having the bottom shelf on runners for the amp? With a grill in the skirting there would be some cool-ish air coming in.. Add some nice slots in the shelf itself to allow air to rise backwards (get sucked up by the fans on the amp). Have the shelf above with air slots as well.. and a big cutout(s) at the top/back where the wall is to allow heat to escape.
Would you look at mounting another fan on the top of the unit to help suck everything out? That could be covered in a nice grill too (girlfriend approval pending :o )
Ok guys well I've just been thrown a massive curveball here and feel rather stupid.
What I was assuming from my AV knowledge circa early 2000s (lol :confused: ) was that soundbars plug into AV receivers. I have now been told that they are all active speakers and do no such thing :o
So in short, the living room layout dictates that a soundbar is the only way forward. There's nowhere to put even left/right front speakers. It's a small room. So, does that dictate that I may as well get rid of my Marantz receiver? :confused: :( And if I'm going to do that... I barely need to have a conversation about cooling the built-in alcove units do I?
That’s really sad, but yes, soundbars tend to all be active devices. Don’t despair, you can get half decent results with them. Shame to get rid of the Marantz, is there anywhere you can set it up for music duties while you figure out a proper cinema room?!
Who are you going to for advice? Their knowledge seems poor.
Yes, most sound bars are self-contained devices where the speakers and amplification is built into a single box. The standard way of doing things is to have the sources connected directly to the TV HDMI sockets, and then use the HDMI ARC/eARC output as a way to get audio to the sound bar.
For a lot of people with an older TV, the need for ARC is problem. Your GT60 does support this though, but you'll need to enable HDMI Control (Viera Link / CEC) in order to get it to work. That can mess up the control from your Harmony because the remote will be trying to drive the system but CEC will be interfering and trying to work its own way.
You do still have the option of avoiding CEC by using optical. At some point though this connector will be phased out on new TVs, so whilst you don't need to work around this immediately, it is something to bare in mind for the future.
What your advisor is missing is that passive sound bars exist. They're not giving you good advice.
Passive sound bars are in effect the front three speakers in a single speaker cabinet. If you have a look at the Monitor Audio SB-4 you can see the idea. It's a centre, a left, and a right, with three sets of speaker connections at the rear. This connects to an AV amp exactly the same way as three ordinary front speakers. This leaves the option open to use conventional surround speakers towards he rear of the room, and even ATMOS in-ceilings, rather than relying on bounced sound from a sound bar where all he speakers are built into one place.
Well, we bought our place in London 18 months ago. And, it's London and a small terraced house and I'm not a millionaire so we can't afford anything bigger :p :( I also have my old Marantz stereo amplifier in the loft which I was holding on to for musical duties. But now I'm in long-term-relationship-compromising-stage of renovating the house I think it highly unlikely I'll win the argument to wire speakers around the dining room/kitchen living area either. Active wireless speakers seem a more likely option (we're currently making do with Google Home minis, for reference).
It's my knowledge circa 2010 :D Before I had any idea I would end up buying a place for myself in London I had grand plans for a proper 7.1/Atmos setup and sniffed at those poor souls that "made do" with soundbar setups. But now I live in the real world where I feel very lucky to have my own place, but a cinema room it certainly isn't!
For reference, here is the lounge about a wek after we moved in. We'll get built-in alcove units like the picture I posted above.
The room is barely 3.5m wide, the telly shown is the aforementioned 42" Panasonic GT60. And the alcove itself behind the TV is just over 1m wide. So any new TV is going to be a 43" max.
I think I turned CEC off on the TV :confused: I'll have a look tonight. But if the Harmony goes, it goes... I understand they're end of life with Logitech anyway now?
Thanks for the info. Realistically though, wouldn't I get a better experience with an Atmos soundbar with (possibly) small rears and a sub? Rather than 5.1 on a passive soundbar? On that subject, looking at the room and layout (layout will be the same), would it be possible to put a front-left speaker on the far left bookshelves? And the front-right would be pretty much above the TV. If I did that and maybe got a centre to mount under the TV, and small rears... would Audessy actually be able to tune them all properly? Or would it be weird with the left speaker so far out? :confused: Wires would be an issue (argument) though...
Anyway I will certainly investigate passive soundbars... In fact I will wander to Richer Sounds shortly as there's one near my office.
Re: passive sound bars; stuff suchbas the Monitor Audio is just the front 3 speakers. Obviously then it's not trying to do side surround or anything with height effects.
The results with a 5.1/Atmos sound bar depend partly on the quality of the bar, but a lot rests on the room and where the bar is positioned within it. In order to create the illusion of speakers the sound beams need something to reflect of that also allows the sound to then bounce towards the listener. The place that's the most difficult to get this working is the traditional corner of the room placement. The angles for the reflected sound are difficult. You can try this yourself with a hand mirror. You'll need someone to help though. Sit where you would normally and have your helper move the mirror until you can see the place where the sound bar would be located.
The same limitations are true for virtual atmos height speakers.
Appreciate the points there @lucid . I started down another rabbit hole "what if I got a 3.0 passive soundbar, then found some wireless atmos upfirers for the bookshelves.. and rears, and a sub". But then I would have spent £1500+ which is totally not worth it for this room (and huge point to make - my girlfriend is so paranoid about noise re. the neighbours we'll never watch anything at what I'd call a 'decent' volume anyway) plus the expected £1,000 on the TV and I just can't spend that right now. Unless you can find me a passive 3.0 soundbar with wireless rears, subwoofer, and atmos up-firers for under a grand all in? :D
Also, in complete laymans terms if I want to wall mount the TV and soundbar then it'd going to require trunking some cables against the wall from the receiver up to the soundbar and that's jusst a lot of effort for something that probably wouldn't pass the girlfriend test. lol :rolleyes:
I'm pretty set on TV choice if I go this route. Probably Panasonic but maybe Sony. It's the soundbars I know nothing about. I think I need to start a new thread entitled "spec me an Atmos soundbar <£600 with a sub, and the ability to add wireless rear speakers at a later stage" ...
Sometimes we have to make compromises in order to get some of what we want. It's that or nothing, so a bit of flexibility is the answer. In your case it sounds like you're heading towards a sound bar.
I did wonder whether the 5012 has HEOS (it does) and whether it supports HEOS wireless rear speakers, which it doesn't, sadly. Not that that would have got you Atmos rears. That isn't a feature of the HEOS speakers yet, AFAIK.
I think your amp does support Atmos though, either as front heights or mid heights. IDK if anyone is doing a passive sound bar with upfiring speakers, so I think your back to a sound bar.
Both Denon (via HEOS) and Yamahe (via MusicCast) support wireless rear speakers for certain models of their respective sound bar ranges. This means that the sound bar can do the front three channels plus upfiring ATMOS, then the HEOS speakers do the side surrounds.
Regarding cabling: You were concerned about having to trunk speaker cables up the wall with a passive sound bar layout. We'll, I think you need to know that with a powered sound bar that you won't need the AV receiver, but you will need to trunk power for both the TV and sound bar (unless you have power sockets installed in wall), and you'll have HDMI cables from the ATV box and Sky Q box up to the TV. There'll then be a HDMI cable from the TV ARC socket to the sound bar.
That's a good point. Having only used the amp for 2.0 setup with my floorstanders I've never really investigated HEOS capability. I've just done some reading but couldn't find anything about HEOS surround, what did you find that makes you think it's not possible? I actually just sent a ticket to Marantz support to ask them. Shame that Atmos isn't supported though.
This occurred to me during a very boring meeting at work. lol. I don't know why I hadn't realised that before. So actually on the flipside a passive soundbar might mean less cabling up from the unit to the TV arm. As it would be just the TV and soundbar - from the amp. As opposed to every single device (Sky, ATV, Bluray etc.).
I am now re-thining the idea of keeping the receiver and finding a passive soundbar. I'm not sure I could convince my girlfriend but we still have builders in doing all sorts, and for one he is in next week doing skirting in our dining room (we've had walls taken down, a new kitchen etc. it's a long story). So potentially asking him to replace the skirting from the alcove unit round to behind the sofa (maybe 4m worth) with rebated skirting i.e. a channel for speaker cables is entirely possibly and I'd like to think not a huge cost either. That could all feasibly be done before the decorators come in and it hence could be done very well and hidden.
So that leads me to more questions... (arrgh!)
  1. If a wired 5.1 setup using my receiver and a passive soundbar would be better than an Atmos soundbar/sub/rear setup. Or if I'd miss Atmos.
  2. Or even, going back to basics, would a 3.0 passive soundbar with sub actually sound better than an Atmos soundbar with sub (and no rears)
  3. If the above setup would be better for music (meaning the passive soundbar)
  4. If there would be any way to add Atmos speakers without running more cables. (I ended up in a rabbit hole of looking at the Rocketfish wireless speaker kit etc.)
Lastly, back to the original question about ventilation (lol), the carpenter was round taking measurements earlier and his suggestion rather than grills on the front of doors, was to open up the skirting on/against the floor. A bit like this but on the cupboards (not the weird middle thing they've got going on here); https://imgur.com/Td4prg8
Re: no Heos rear surround with the 5012. I had a quick look at the manual and also checked some product comparison sites. There's also this from the Marantz web site. https://support.marantz.com/app/ans...-speakers-compatibility-with-marantz-products It suggests that the Marantz range doesn't support Heos speakers as rears... at all!
Side note. Your receiver is 7.2 (7 ground channels + 2x subs). That means the most you're going to get in an Atmos configuration is 5.2.2 (5 ground, 2 subs, 2 (a stereo pair) Atmos speakers). This then means that the Atmos speakers can't be rears. They have to be front or mids. The amp doesn't support dedicated Atmos rears. You would need a 9.2 amp for that, and for it to be configured as 5.x.4 (5 ground, 1 or 2 subs, 2x pairs of Atmos speakers - 2 front, 2 rear) Read more from the Dolby site with layout pictures of all the various configurations here: https://www.dolby.com/about/support....1.2-dolby-atmos-enabled-speaker-setup-guide/ FYI - the site shows upfirers I think mainly because this is the easiest route for most people retrofitting. Real speakers located where the sound is supposed to be coming from will always trump reflected sound speakers.
I think that with the builders in that this is the perfect opportunity to run and hide cabling. More than that; it's the perfect time to plan to run cables in case you might change the amp and add any extra channels. Compared to the cost, disruption and mess of opening up walls a couple of year after the room has been fitted, decorated and furnished, running some extra wiring now is the cheap and quick option.
I'm going to keep coming back to this because I think it's really important. The angle of reflected sound with upfirers really needs some thought. In very basic terms, if you go for upfirers, and the sound bounces off your ceiling but doesn't reflect back to where you're sitting - if it misses you - then you're going to be disappointed with the results and she's going to wonder why you spent good money on this.
There are a couple of other things to think about as well.
1) Volume matters: Sound dissipates over distance. (look up the inverse square law) So, if the sound has to fire up and then reflect off the ceiling before finally reaching you then those speakers are going to have to be driven harder than the main channels in order to keep up. Harder working speakers means harder working amps, and harder working amps means more heat. That is one of your prime concerns: heat. That's what started this discussion.
You're running 2 channels with the Marantz and have USB cooling fans fitted. Think about how it will be running all 7 channels and with the amp parked inside a box.
2) In-ceiling speakers work better, but they cost a lot and take extra effort to install. Also, the sound from them goes up into the room above as well as down to where you're sitting. There are ways to minimise this such as with Dynamat, but there still some extra noise there you should plan (and cost) for if this is the direction you might head.
Here's an alternative solution: Have a think about front presence speakers. These are mounted up high on the front wall, and angled down so that they fire at where you're sitting. These can be good, ordinary speakers. Something with decent sensitivity that are going to give the amp an easier time to run. Have a look at used Monitor Audio Radius 90 speakers. The older versions with 87dB/W/m sensitivity, not the newer ones that are 84dB. They even come in room friendly colours - e.g. white
Have a read here of the results from someone trying exactly this sort of layout. It works for Atmos and for non-Atmos content too. https://www.avsforum.com/threads/svs-prime-5-1-4-atmos-speaker-system-review.2141362/
This could allow you to have the 3 channel passive centre, then some discrete front heights with the cables hidden up the walls, and that just leaves you with the 'rear' cables to hide for the side surrounds.
Atmos (and/or presence) vs standard 5.1: The extra channels do help lift the lid of the room. However, for the effect to come alive then the sound level has to be 'sufficient'. It's not going to be noticeable if you're just cruising along barely louder than the TV speakers can play. That wouldn't stop me putting the wiring in ready. But it might encourage me to do this in stages if my significant other was so worried about the neighbours. Front channels & sub first. Then add side surrounds. Then add presence speakers.
Sound quality: There are some very good sound bar systems now if you're prepared to throw down a chunk of cash. 'A chunk' generally means something north of a grand, and maybe as much as £2-2.5K. For someone only interested in TV and movie sound then it's getting harder to justify a traditional AV receiver speaker package system. It still holds the high ground, but with so much being watched via streaming, and where the best that sound gets is DVD quality lossy DD5.1 (+Atmos), then for many the convenience of a sound bar or wireless speaker system tilts the balance. It's not as good, but it's good enough.
What separates the men from the boys is music. A good amp with decent speakers.... that's where sound bars struggle to compete.
Re: adding Atmos speakers without extra cabling. With your current amp, see what I wrote above.
Hi @lucid I very appreciate the detailed response again. Sorry for the slow reply.
I spent the weekend looking closely at a lot of the passive soundbars out there and I think the decision has almost been made for me. Or at least, has confirmed the way I was leaning anyway. The alcove is only 1m wide and none of the top/available passive soundbars are that short anyway. But I think there's a lot of plus points for going the soundbar route;
  • We don't actually listen to much music in the lounge (more kitchen/dining for louder/proper listening). Music is generally just out of the Google Mini (mostly radio in the morning).
  • I can get something that supports Google Assistant/Cast which will be an improvement on the Mini for those occasions we do listen to music.
  • I can ditch the Harmony Hub/remote which will make my girlfriend happy.
  • We don't need to compromise the aesthetics of the cabinet for cooling (e.g. no holes in front).
  • New TV required, but we can put the Panasonic up in the study as a second TV when required (something we'll occasional need, and I do have a SkyQ mini gathering dust too).
  • No paying for new rebated skirting/work around the lounge to hide wires for rear speakers/sub.
With that decision made I don't necessarily need to decide on gear right now although I understand now-ish might be a good time to get a deal on last years TVs? :confused:
I said it on Friday in post #16, you are heading for a sound bar ;) :D :D :D
Regarding a TV, if there's something that meets your needs, and it's at a price you can afford, then just get it. Stressing over the right time to buy a TV is a waste of energy. Check out the reviews at Rtings to make sure there are no glaring shortcomings.
Good luck :)
