Fitting and old hard drive.
~J~
~J~
20 Oct 2003
London
Does anyone know if a 20Mb HardDrive from 1987 (Probably ATA33) would be compatible with todays IDE cable AND be picked up by Windows XP.
The harddrive is running MS-DOS 3.2.
Need to know before I dismantle the machine :)
Should be fine. Just watch that the BIOS doesn't reset the boot order on you or you'll find yourself transported back to 1988.....
