ive ordered some pioneer 6x9s (due tues) but i have now a new pioneer headunit and some pioneer componant speakers. couple questions as ive taken the side door off and what I can see.
1) Do I put the cross over box in the door aswell, the cables dont look that long
2) the existing standard pug speakers obviously have its own connector and its different, can I use this or should I buy speaker wire and fit somehow, if so how.
3) Im tempted to buy an amp but will have to wait for few weeks, is it possible to hook up the 6x9s and the compants to the headunit or should i wait for a bit.
4) the speaker looks like it doesnt fit in the door, its bit deeper then the standard speakers do I have to drill something out?
any help would be great
thanks
thanks
