Got it in the post yesterday, fitted it last night but not sure if I've done it correctly (instructions included were lacking to say the least).
Is it correct to tighten the sprung screws until they won't turn any more, or should I just be doing a few turns on each corner?
I probably need to remove it anyway to ensure there's enough TIM in the void gaps between the heatpipes, so would love to do it correctly when refitting.
