- 13 Jan 2004
- Leicestershire
to make it into the same height as rooms all the way along and block off the 'wasted space' on stairs.
I've measured the bottom - standing on floor to ceiling is 7ft. So gone up stairs and measured 7ft from step to where ceiling will be. I've then tapped 2 nails in and tied string around them to get a straight line. Will put wooden lengths onto walls to screw plasterboard up from underneath. Thinking i'll need to stick few pieces of wood across at top, bottom and couple in middle to strengthen fixing so 9mm plasterboard doesn't sag.
Then once done, get it all skimmed over, paint it and job done.
sound as easy as what I'm thinking?
