Fix IP on a wireless network
19 Oct 2002
Hi
if you fix your IP on your internal network to say 192.168.1.12 and the router is providing dynamic ips for the rest of the devices - what is to stop 192.168.1.12 being allocated first to another machine then you log on and try and set that IP as your own fixed one ?
just thinking, if I set mine to a high no. (12 isnt bad anyway) say 192.168.1.55 I could be pretty sure that no one would be allocated 192.168.1.55 ?
any networking bods agree with this ?
also, maybe option to fix the ip on every device on the network but that doesn't sound a good idea
this is a home network so experimental use really - portforwarding to 1 pc only
thanks
Hi
its a HG533 Huawei TalkTalk - didnt know you could give a range to DCHP - i'll have a look
just checked (its 1.14 firmware, much faster than 1.13 menu wise)
Basic > LAN > DHCP
DHCP Server
Help
DHCP server: Enable
Start IP address: 192.168.1.2
End IP address: 192.168.1.254
so I could limit the End IP address to say 192.168.1.100 and fix mine as 192.168.1.120 ?
Excellent
Sin Chase - just as I scrolled down the page i see (new to this router) :-
DHCP Option Pool
Device type:
Option60:
Start IP address: *
End IP address: *
DHCP relay: Enable
IP Address Reserve
New Remove Help
Index MAC address: IP address
IP Address Reserve looks good enough for me at the moment
Is this sort of level covered in dummies networking type of books ?
Thanks for your help guys
