- 29 Jul 2004
Sorry but they arent great, toggles or even wall anchors are stronger than the grip it fixings for plasterboard, the best ones are the geefix.
I've got mostly hollow stud walls on internal walls due to buying a new build.
When I buy a bigger TV I will be wall mounting it, but I wouldn't trust any of the plasterboard fixings to hold it. What I plan to do is cut away part of the plasterboard, and make a wooden frame attached onto the studs which the bracket would attach to.
I also would at the same time run the cables down inside the wall to near the bottom for a stealth look with no wires. Just a suggestion.
I've tried a most of the fixings mentioned, but I wouldn't trust any of them for a TV, as at the end of the day they're only as strong as the plasterboard is, which isn't very strong.
