Fixing tube in place
17 Jan 2006
I will shortly be putting a short piece of waste pipe in the ceiling from my bedroom cupboard up into the loft but I'm just wondering the best way to hold it in place, could I just use a bead no nails or something round the pipe either side of the plaster board?
won't it be held in place by whatever pipes it's connected to? so all you really need to do is make sure you don't do the hole to big and then maybe use some silicone sealant or whatever to fill the mm gap ?
is this a pipe? of flexible ducting? and you are exhausting hot air and carbon dust? *cough*
the ridges on the ducting should hold it in place anyway , don't forget to insulate your loft or the snow will melt *cough*
PVC pipe is normally fixed with the appropriate U shaped wall brackets, have a look in your local DIY shed, they will be in the same section
If pipe comes between two joists, just screw a piece of wood across them to fit pipe clip, if the pipe is solvent weld, get a small off cut of pipe, & cut it lengthwise, slip it around pipe & glue in place just above pipe clip,
This will stop the pipe sliding down.
EDIT: More details, :eek:just drill a hole in some ply same size as pipe, slide it through & glue on a straight coupler if it's solvent weld pipe.
Knew I shouldn't have posted in a hurry whilst being harassed by my baby boy! It's not going to connect to anything, it's just to make it nice and simple to run cables down from the loft into the room! Lol. Should have mentioned that really!
Pipe clip?
I did thank about those but it's going between the chimney and a joist but there's no room to get to the joist as it's only a small gap.
That might be doable or something similar....
