Hey guys, Am about to reflash my 780TI. Following the steps I found on this forums when pick the rom it comes up with
WARNING: Firmware image PCI Subsystem ID <3842.2884>
does not match adapter PCI Subsystem ID <3842.2883>
Is this normal?
If you're certain that is the correct bios you need to flash, you can use command -6 to override subsystem mismatches.
Hello,
normally there is no BIOS update needed for your card. What is the reason you want to flash the BIOS?
Please be carefull with the BIOS you flash because sometimes there is a new BIOS number if we use a different RAM model, if you then flash this BIOS on your card it might not work anymore.
You can also raise with the precision tool the temp target then the card will not clock down. If you have games where the clock is jumping up and down you can use the Kboost feature of precision to fix the clock where you want. The numbers that are stated at your post do also not match, one is the Ref clock P/N while the other is a SC one.
Are you sure its not hitting the Power Limit and that is why it is down clocking?
flashing GPUS is not for the faint of heart,
much better if you have a card with a backup bios at least but if not its heart in mouth stuff everytime. I've flashed many a bios over the last couple of years (mainly down to mining on 7970s and chopping and changing bioses every other day. and every time its nerve racking
personally i'd drop Dominik a quick mail and run through the options with him. he's a great help on here and i'm sure he'll be happy to help you get the most out of your card as it is without flashing.
if your still having issues just check, double check and triple check everything from the bios down to the flashing tool is compatible with your gpu and hope for the best.
obviously even a bad flash isn't the end of the world as it sometimes can be reversed but be warned not always. Rather expensive paperweight if it goes wrong
Ive seen it hit the 106% power limit once or twice but it never sits on it... Surely its not hitting the power limit already?
Just leave it alone. Are you visually really noticing a problem?
^What limit???
K Boost on Precision is not working 100% of the time for me. Often BSOD on apply and you have to reinstall driver. If it works correctly on your rig great tool to stop clocks jumping around.
The throttling your suffering is common on Gk110
Yes, you can hit the limit very quickly when overclocking
