- 11 Oct 2005
- Doncaster
Which one would you get now the flint 3 is on pre-order.
Not sure clock speed and core count are best indications of performance outside of the same generation. If we assume it’s the A53 thats suspected, that same SoC is in the UDMP and does IDS/IPF at 3.5Gb/s and NAT at way higher, while also being an NVR amongst other things. What concerns me is this is the router for yesterdays connectivity, 5Gb wholesale is about to roll on CF, more is expected next year, a 2.5Gb limited product with 1GB of RAM feels like a F2 refresh, not so much an F3.I would want a bit more head-room on the cpu 1.5GHz quad core would be deal breaker for me, my old Cap AX has 1.8GHz,
I was looking at it as well for the wifi 7 ellement and 2.5g, wifi is complex enough on tik but I still want a wifi 7 AP for upstairs as thats where all the best kit is.I was sort of tempted by the flint 3, despite owning an Mikrotik rb5009, but missed the super early bird offer yesterday so fomo has left the building and will wait for other revews
More or less just an AP, but if I can find a decent 2.5gb switch with at least one sfp+ cage I'll go with that and look at a couple of wifi7 access points. Alternatively I'll move the wan port which is 2.5gb on the Mikrotik to one of the 1gb interfaces and use the flint 3 as an AP on the single 2.5gb interface.I was looking at it as well for the wifi 7 ellement and 2.5g, wifi is complex enough on tik but I still want a wifi 7 AP for upstairs as thats where all the best kit is.
What was you thinking just for an AP ?
I had BRSK installed on Friday and I was eyeing up getting a Flint 2 or 3 router to go with it.
The Flint 3 is currently on offer at the rainforest, so I took the plunge today.
Also in a bit of a freak circumstance, LTT did an upgrade video today using the Flint 3 and the wonders of Wifi 7.
Ok so a little time has passed and the Mikrotik Hap be3 Is about to be released with 2GB of Ram. Does your argument still stand cpu wise ?Not sure clock speed and core count are best indications of performance outside of the same generation. If we assume it’s the A53 thats suspected, that same SoC is in the UDMP and does IDS/IPF at 3.5Gb/s and NAT at way higher, while also being an NVR amongst other things. What concerns me is this is the router for yesterdays connectivity, 5Gb wholesale is about to roll on CF, more is expected next year, a 2.5Gb limited product with 1GB of RAM feels like a F2 refresh, not so much an F3.
The devil is in the detail. Firstly a correction, the A53 is used (with 3GB of RAM) in the UDR7, not the UDMP or SE as I said, they are A57/4GB, but all are 10Gb WAN class products, so choosing to limit the product to 2.5Gb simply to create an upgrade cycle for 5/10Gbit is simply marketing/introducing interim upgrade cycles for the sake of it.Ok so a little time has passed and the Mikrotik Hap be3 Is about to be released with 2GB of Ram. Does your argument still stand cpu wise ?
I know you won't agree with the 2.5Gbps ports but other than that is this device worth buying in 2026
