I think so long as the inlets/outlets are not all lined up you should be good, otherwise the water has a tendancy to flow straight through the bridge and not through the gpu blocks.
Found these images by ek, should help. I'd personally go for this
instead of
I don't think in a dual setup it would matter which inlet outlets you use, gpu blocks are not (yet) like cpu blocks that have jet plates and need the center hole to be used as inlet.
