- 28 Oct 2020
Hi, can I use what is supposed to be the fill port (red arrow) as an OUT? There is a fill port in the case I could use instead.
If so, then could I also use the out port (green arrow) as a drain?
The GPU wont be in the loop until next gen for obvious reasons.
Also is there anything wrong with the whole thing except (I know there's more fitting than theoretically needed but I can only do 1 bend per tube).
https://1drv.ms/u/s!ApDZ5zl1onU8gtsLWGi7qcunnvNlpA?e=3Zh9ny
