Flushing system
6 May 2011
Hi
I have taken my loop apart for an overhaul. Can I usr warm water to clean or do I need distilled water, or I read something about vinegar?
Also, been using Feser 1, any better stuff out there in your opinion?
to flush you system you can use warm water or cold how eevr when you have finished rinse with Di water to get the chemicals tap water leave behind out.
What is the best way to flush??
Have a hose for the pump going into a bucket full of Di water and the hose that would normally go back into the res going into a different bucket and let it flow through??
I flush straight down the drain. larry @ West Coast Mods has a vid on the Tube that is perfect for recycling water. He using a 50 micron filter.
