Now things have settled and I've got the client past 10 WUs complete I seem to be getting around 16000 PPD crunching through 4 WUs in a 24 hour period. There might be a token slacking for an hour or two when I'm gaming, but most of the time the PC has only been crunching. This seems a bit low to me?
There is no GPU client running. I'm running the SMP 6.34 console client using a shortcut (dunno why but the service mode wouldn't run in SMP), with 8 cores (includes hyperthreading). No apparent crashes.
I suspect I can push the clock higher in due course. Temps are only hovering in the 61-64 deg range under load. But I'll worry about that later if I can squeeze a bit more from the folding in the first place.
