As per topic. Im trying to get some information to make some decisions. If you could go through the Questions and answer them as per your setup i would be grateful.
Q1: ISP and Connection?
Q2: Router Make and Model?
Q3: Do You use a Software Firewall? If yes, which one?
Q4: On the Router, do you use "Static IP" or "Auto DHCP" setting?
Q5: Which Software do you use to Stream or Send Files to PS3?
Q6: Do you use FlashFXP or any other ftp software which requires "port forwarding on the router"? If yes, what settings do you use?
