Ford Focus 2010 Titanium part required
5 Aug 2013
Shropshire
It's finally happened again - wife went out to garden center and when parking she went to far and front bumper/undertray bit rode over the high kerb - As she reversed off a few bits of plastic came off also.
What has broken is the plastic shield directly behind the base of the front bumper - Looking at it it is not a small part but looking at all the google pictures I can't seem to identify it - some say under bumper crash absorber but it looks nothing like I think it should.
Can anyone identify this plastic panel for me please or point me to a body diagram showing all panels.
Fortunately I have been able to cable strap all lose flappy bits and it should be OK for a while - just means water can slash up over engine tray and everything else.
If only I could afford a cheap car just for her.
Is this even worth fixing on a 2010 Focus? I'd just rip off any remaining undertray and forget about it?
That thought had occured to me :)
tl45
It could very well be that is damaged but I have other bits from it that look like those three smaller bits in front of it.
My wife is a old woman that normally drives carefully but occasionally has a senior moment - I don't think she has ever been competent. - I just with I could have married VBH then I would never have worried when she went out.
Did that on my XJ6 after running over a tree stump embedded in some loose grass: never bothered replacing it and it didn't seem to affect it at all.
Probably affected the aerodynamics by a tiny fraction, but yeah, just rip it off rather than worrying about this.
As said wouldn't worry about it, cars never used to have the undertrays and they were fine. I have noticed a few people when parked up face in to the kerb have the bottom of the bumper touching it. I am sure newer cars are getting lower as one of the managers where I work reversed into a space at work and when he drove off the entire bumper of his A4 was ripped off.
