forgotten xp pro password
3 Sep 2007
Help me please,
i use xp pro and did not have a password for my account and now it is askin me 4 1.
i can get into the guest account but it has limited access :(
any suggestions hw i can get into my admin account
thnx in advance
Start
Run
type "CMD", then hit Enter
type "net user administrator *" where administrator is the account name you want to change, hit enter, then for no password, hit enter again.
Log out of the Guest account and press: Ctrl + Alt + Delete, twice.
The in the user name box, enter, "administrator"
Leave the password blank and press enter.
Hope the works...
Damn.
Go to Google and type in, "Forgotten XP Password".
There're a few ways of getting it reset..none of them however is an easy task. I would back up what you can and format + reinstall Windows. But, try Google first, only format if you have pulled all your hair out and at breaking point, after Google gives no help...which it will, but expect to be there all night. :(
Yes, normally the Administrator account. Which I asked you to try.
Have you ever had any passwords on the PC?
