Format before or after?
28 Nov 2005
Im going to be getting a new motherboard soon, (current one borked) and i was wondering is there a preference on formatting the hard drive before i install the new motherboard or after,
or does it not really matter, i only have windows on the hard drive, but i have all the old chipset drivers on from the current motherboard?
the hdd is in 5partitions, one being a partition just for windows (6Gb-ish)
all other partitions are clean.
thanks
I dont think it really matters if you just formatting but its recommended you do a clean install after you installed your new motherboard getting rid of any traces of the old motherboard software.
